1978 - 1996 Big Bronco
Idle Issue?
Old Jun 12, 2007 | 11:42 AM
hdwilly's Avatar
hdwilly
Question Idle Issue?
My '89 Bronco w/351fi has an issue with returning to idle. When you rev the motor the engine speed first drops to about 1,200 rpm for a few seconds and then to normal. I already replaced the FPR, and the TPS. I checked the IAC and it ohm'd out according to spec and didn't seem gummed up. It has a fresh tuneup with new plugs, wires, cap & rotor. Also haven't been able to find any vacum leaks anywhere. The idle isn't really erratic it just stops at 1,200 first and then drops.
Anyone have this happen or have any ideas?
Thanks in advance for the help!
Old Jun 12, 2007 | 11:47 AM
Gacknar's Avatar
Gacknar
Is the TB closing all the way as soon as you release the throttle?
Have you checked for any codes?
Old Jun 12, 2007 | 12:10 PM
hdwilly's Avatar
hdwilly
Codes are clear right now. Throttle Body doesn't seem to be sticking and closes all the way from what I can tell. I ran across info in a manual that listed procedures for setting the TPS. I know we didn't do that when we put a new one in as I had no idea it was adjustable. Maybe it's thinking the throttle is at different setting than it really is?
Old Jun 12, 2007 | 12:23 PM
Gacknar's Avatar
Gacknar
Could be, test it and see.
http://fordfuelinjection.com/index.php?p=30
So you get code 11 when you run a self test?
Old Jun 12, 2007 | 12:32 PM
hdwilly's Avatar
hdwilly
The computer isn't actually throwing me any codes right now. It did initially which is the reason I replaced the TPS. It hasn't thrown that code again since so maybe I do have it set right (by dumb luck) and I have other issues?
Old Jun 12, 2007 | 12:49 PM
Gacknar's Avatar
Gacknar
If it wont give any codes at all during a self test then you either have a wiring problem, a blown check engine light, or a bad computer.
Are you sure you are running the test properly?
http://fordfuelinjection.com/?p=13
Even if everything is fine you will still get code 11
Or are you not actualy running the test becouse you havn't gotten a check engine light?
Only about half of the codes will triger the check engine light.
Old Jun 12, 2007 | 01:03 PM
hdwilly's Avatar
hdwilly
I didn't realize I'd have codes even if everything is "ok" and no check engine light is on. I'll go back to Square 1 and re-test to see what shakes out. Then I think I'll pull the battery cable to re-set the computer, drive it some more and see what happens.
Thanks Gacknar - I'll report back with findings...
Old Jun 12, 2007 | 01:07 PM
Gacknar's Avatar
Gacknar
Yup, it may give you 11 (system pass) but it may give you one of the codes that wont triger the light. Either way youll know for sure
Your welome
Timus
Jul 5, 2012 07:59 AM
smokersteve
Mar 15, 2011 04:47 PM
daring
21
Nov 21, 2009 09:51 PM
nutfarmii
20
Oct 15, 2008 06:17 AM
F0rdF0rever
1983 - 2012 Ranger & B-Series
Oct 27, 2005 10:47 AM
