02 sensor replacement causing backfire??
I changed the o2 sensor on my son's '91 F150 302 AOD, hoping for a little gain in MPG. It looked exactly like the one I removed. A bosch unit, got it from Rockauto.
He indicated this morning that it was backfiring while accelerating from a stop and when it shifted gears.
Couple things; could an o2 sensor R&R cause a backfire? Is there a torque spec for an o2 sensor? Could I have overtightened it?
First thing I'm going to try is replace it with another sensor, since it ran pretty good prior to replacing it.
Anything else I might check while I'm poking around?
Thx.
Thx.
Rubicante
04-20-2000 08:52 PM
