02 sensor replacement causing backfire??
Old Sep 20, 2011 | 11:48 AM
bryyce62's Avatar
bryyce62
I changed the o2 sensor on my son's '91 F150 302 AOD, hoping for a little gain in MPG. It looked exactly like the one I removed. A bosch unit, got it from Rockauto.
He indicated this morning that it was backfiring while accelerating from a stop and when it shifted gears.
Couple things; could an o2 sensor R&R cause a backfire? Is there a torque spec for an o2 sensor? Could I have overtightened it?
First thing I'm going to try is replace it with another sensor, since it ran pretty good prior to replacing it.
Anything else I might check while I'm poking around?
Thx.
Old Sep 20, 2011 | 01:08 PM
Lazy K's Avatar
Lazy K
Look for any exhaust leaks. Maybe around the sensor bushing or where the pipe joins to the manifold, maybe the joint was disturbed when fitting the new sensor.
mikerans
18
Mar 20, 2013 01:00 PM
f142f142
1997 - 2003 F150
Jun 22, 2011 09:05 PM
foxykool
Exhaust Systems
Jan 4, 2010 11:24 AM
nastruk95
General Automotive Discussion
Apr 27, 2004 07:32 PM
Rubicante
Apr 20, 2000 08:52 PM
