1948 F Series Trucks
Old 09-21-2011, 02:29 AM
Barthog34's Avatar
Barthog34
Barthog34 is offline
Thanks for the tips on how to post pics.
Here we go.....
This is the larger of the 2 trucks.
Old 09-21-2011, 02:33 AM
Barthog34's Avatar
Barthog34
And the other one...
Old 09-21-2011, 06:10 AM
lexcoe's Avatar
lexcoe
lexcoe is offline
is that a spinner ute i see in the background?
Old 09-21-2011, 07:55 AM
mtflat's Avatar
mtflat
mtflat is offline
If they were US trucks I'd call the smaller one F4 or F5 because of the single spd rear axle with duals.
Interesting to see the parking lights on the fender like Canadian Merc trucks, but don't see evidence of the trim.
The frame stampings are usually light and hard to read. I scrub the frame with steel wool and then use a strong light at an angle.
Canada (producer of your trucks) used a serial number on the order of: FM81V4812345
This website might help, but I find some of his info confusing.
Mercury and Ford Truck Data Can
Old 09-21-2011, 08:47 AM
Rojak's Avatar
Rojak
Rojak is offline
Welcome to FTE! Looking forward to seeing some pics of those trucks to see the differences. I've seen a few pictures of "utes" which I know is a different thing but not something seen much in the states.
Rob
Old 09-21-2011, 09:47 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Nice trucks! Still weird to see the RHD in the cab. It's like bizzaro world.
I agree with mtflat on the models. I saw the park lamps in the fenders and the ommission of the trim, too. Misture of Merc fenders with Ford model designation.
Old 09-21-2011, 10:30 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
The RHD definitely looks odd (to us, at least ;o), but amazingly interesting. The larger truck has the wider grille like an F-7 or F-8. I've never even seen a picture of any of these trucks before without the lights in the ends of the upper grille bar. Fascinating. If you can post pictures of any tags or marking you can find, that would be helpful.
Old 09-21-2011, 11:43 AM
Rojak's Avatar
Rojak
Rojak is offline
Thanks for posting!
I agree... very interesting and bizarro!
How about some Ford ute pics in another thread. I love those utes! Too cool.
Rob
Old 09-21-2011, 01:37 PM
51PanelMan's Avatar
51PanelMan
Bit of trivia... crawl under your standard LHD truck and look at the transmission crossmember and the right side frame rail. It's mirror-image of the left side of the crossmember and frame to allow attachment of the brake master cylinder and pedals for the RHD. Also, look at the passenger side floor and compare it to the driver's side. You'll see that the area where the pedals would go through the floor on the pass side is stamped for the cut out that matches the left side.
Also, reverse the instrument cluster and turn the gauges upside down and you have yourself a RHD cluster.
Old 09-21-2011, 02:16 PM
Greg M-47's Avatar
Greg M-47
Greg M-47 is offline
I never even noticed the fender lights the first time I looked. That does look like the Mercury light mount. Got any close up pictures of the fender mount and the light bezel ??
Greg M-47
truckdog62563
1947 and Older Ford Trucks
07-07-2019 11:59 AM
Aaron81
04-23-2019 03:16 AM
thomc
08-04-2018 08:08 PM
mixon72
04-23-2011 09:58 PM
ozzywitda54
08-18-2007 11:39 AM
Quick Reply: 1948 F Series Trucks
