serial number
Old Aug 18, 2007 | 12:23 AM
ozzywitda54's Avatar
ozzywitda54
serial number
i have a 1954 f250. i read in my parts magazine that this year and model has the serial in the driver side door but i cant find it. how was it put on the car? is it possible that its not there anymore? is there any other way i could get it?
thnx in advance
Old Aug 18, 2007 | 01:21 AM
Fomoko1's Avatar
Fomoko1
Canadian Ford/Mercury trucks had the Vin plate screwed on to the inside of the glove box door and the serial number stamped on top of the frame rail. In 1956 the plate was fastened to the driver`s door front pillar, at least in Canada.
Mine were on the driver`s side between the left front wheel and the steering gear box. The serial number stamping was very hard to find as it`s a faint stamping covered in 50 years of rust and dirt.
Old Aug 18, 2007 | 11:39 AM
wmjoe1953's Avatar
wmjoe1953
The U.S. trucks for 53-55 was also screwed to the inside of the glove box door. If not there, Iwill second fomoko1 on the frame rail. Passenger side anywhere from the radiator crossmember tothe right front cab wing. It could also be on the radiator cross member. It is usually on the frame rail between the crossmember and axle though. Wire brush, and solvent to get it clean enough to read
