1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Single or Dual steering stabilizer???
Old 09-15-2011, 12:05 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
BDS Duals work on a stock truck:
Old 09-15-2011, 01:47 PM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
Anyone have a picture of the Top Gun setup? The bilstein setup is pricy, but I'm a sucker for matching stuff (going with Bilstein shocks soon).
Old 09-15-2011, 02:05 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Originally Posted by SuperDutyScaler
one thing i like about the 05 and up SD's is that the dual kit sits above the axle centerline. i dont off road my 350 so i dont care but if this was on my 1978 f-150 it would last a week on that truck
The dual steering stablizer kits at TopgunCustomz.com place the stabilizers directly "in front of" the tie rod assembly for both the 1999-2004 and 2005-2010 Super Duties. I noticed that some pics in this tread have them placed 2 inches "below" the tie rod assembly, which are more likely to be damaged while off-roading.
Old 09-15-2011, 02:07 PM
FordxFour's Avatar
FordxFour
FordxFour is offline
Folks, keep in mind that if you're installing steering stabilizers to cure shimmy or wobble, you're masking the problem not curing it. My alignment guy actually removes aftermarket stabilizers until the alignment/test drive is done.
Old 09-15-2011, 02:11 PM
Furian's Avatar
Furian
Furian is offline
Click on the links below for pics. I cannot copy & past the pics due to TopgunCustoms.com website restrictions.
1999-2004 Super Duties:
MarketplaceAdvisor Image Hosting: Full Sized View
2005-2007 Super Duties:
Old 09-15-2011, 02:23 PM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
Thanks. I looked all over their website but somehow missed those pictures.
Old 09-15-2011, 04:44 PM
jchampion116's Avatar
jchampion116
jchampion116 is offline
I run the dual skyjacker and have no problems out of it
Old 09-15-2011, 04:51 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
do these help wear out your ps pumps fast? the dual setup seems like it could be really harsh on the ps pump. but what do i know.
Old 09-15-2011, 05:38 PM
jchampion116
I personally have never had any ps pump problems with mine, ive had similar settups on a few trucks over the years
Old 09-15-2011, 05:47 PM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
I put a dual setup on a 20 year old Chevy 5 years ago... original pump is still going strong. If anything, it probably helps the rest of the front end steering components last longer.
As someone said above though, if you're got a bad shimmy, this is really only masking the problem. You need to make sure everything on the front end is straight and true before adding these.
Old 09-15-2011, 07:06 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
my truck drove perfectly straight and no shimmy at all...but when I hit a bump (pothole), the damn thing went crazy
put the stabilizers on and that instantly went away. You don't have to have any worn components to experience the death wobble. It's just something that happens with a live axle truck...especially a HD one with larger tires
2011SD
16
07-21-2013 10:33 AM
macguy
6.7L Power Stroke Diesel
01-24-2013 12:48 PM
Kyle 4X4 4life
02-03-2011 09:42 PM
star
04-03-2007 10:25 PM
Gage2502
04-23-2006 07:22 PM
Quick Reply: Single or Dual steering stabilizer???
