Sponsored by: Real Truck
Single or Dual steering stabilizer???
Old Sep 13, 2011 | 07:40 PM
Mr Powerstroke's Avatar
Mr Powerstroke
I'm getting ready to put a 4 inch lift on my 05 Crew Cab PS. I'll be running 35x12.50 tires on it and I won't be taking it off road. I pull a trailer once in awhile, but not on a regular basis. So, with that said, is it worth the extra money for a dual steering stabilizer? Or would I be just fine with a single? Oh, and I'm looking at going with the Rancho shocks.
Old Sep 13, 2011 | 08:12 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Dual only IMO
Some come with a single from the factory (mine). I only had 10,000 miles and mine was toast. I installed a Fabtech dual setup last month for $170 (I think). Made a world of difference.
Remember, 35" tires are a hefty load
Old Sep 13, 2011 | 11:06 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My factory has 153k miles on it. I am running 33" tires and have no bump steer.
Old Sep 14, 2011 | 12:20 AM
jc8825's Avatar
jc8825
For 35s I would say dual. For a stock truck, like mine, a single does nicely.
Old Sep 14, 2011 | 06:38 AM
Furian's Avatar
Furian
You Keep What You Kill
One of the best values on the market is the dual steering stabilizer kit from TopgunCustomz.com. They offer a nice "heavy duty" bracket (black or silver) with various shocks to fit your budget.
Basic Shocks - $159.95
Bilstein Shocks - $309.95
Fox Shocks - $449.95
King Shocks - 619.95
Stabilizers (Ford 05-07 Super Duty) - Top Gun Customz
Old Sep 14, 2011 | 07:08 AM
Kovster's Avatar
Kovster
Not trying to hijack the thread.......
but instead of creating a new one...
I have an 03' F250 FX4, and the front stock stabilizer is quite rusted and looks like its bent a little?
There any direct fit after-market that will fit there? Like Rancho or something? One I would NOT need to install new brackets for.
-Kov
Old Sep 14, 2011 | 07:55 AM
kd0axs's Avatar
kd0axs
Yes, Rancho makes one that is a direct replacement. I just replaced mine last week.
Old Sep 14, 2011 | 08:31 AM
SuperDutyScaler's Avatar
SuperDutyScaler
dude go dual stabilizer, on my 2004 im only running 33'' and i just instaled a sky jacker dual kit and what a world of difference! i get absolutely no shake's shimmies or any wheel movement at all now. a single shock is not enough on these heavy trucks and the dual kit will make a world of difference, you will be real happy.
Old Sep 14, 2011 | 11:28 AM
CodaMan's Avatar
CodaMan
I went with the dual Rancho setup (under $140 from Amazon). Check out the pic here
Also check out this entire thread
Old Sep 14, 2011 | 12:17 PM
Kovster's Avatar
Kovster
Do you have a p/n by chance?
Old Sep 14, 2011 | 03:14 PM
SuperDutyScaler
one thing i like about the 05 and up SD's is that the dual kit sits above the axle centerline. i dont off road my 350 so i dont care but if this was on my 1978 f-150 it would last a week on that truck
Old Sep 14, 2011 | 04:37 PM
Mr Powerstroke
Thanks for all the comments guys. Looks like it's a unanimous vote for duals. I just wanted to make sure I wasn't wasting money for something that was overkill. I think I'm going to go with the Rancho setup.
Old Sep 14, 2011 | 05:08 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
trust me, you'll like this. remember, that many of the dual steer setups on the 05+ require a 4" lift kit installed as well. The panhard bar will hit the drivers side stabilizer shock on a stock hieght truck.
I think there is one floating around for a stock height truck, but I can't remember the name right now
Old Sep 15, 2011 | 11:19 AM
CodaMan's Avatar
CodaMan
No lift required on my '06 SD with the Rancho Dual setup.
Old Sep 15, 2011 | 11:42 AM
phantomphixer's Avatar
phantomphixer
Rough Country has singles and duals RoughCountry.com
2005 - 2007 F250 / F350 Super Duty SINGLE 87322 - $49.95 DUAL 87491 - $129.95
I used a single on my 06 F350. Solved the dreaded "Death Wobble" Should that every come back I'd do a dual. Instructions were worthless. O yeah right, there were no instructions. Sent them a nasty email. Never heard back. Good quality and fast delivery though.
My $0.02 worth
