GT40'd 5.8....
#46
That Bassani Y-pipe is going to cost you a fortune if you didn't get one back when the dot coms had them at blow out pricing. Just not worth it in my book. More so on the 5.8. Most are not 2 into one, till the cat. On a 5.0 I get it... It would be more cost effective to make it true duel.
OK read it and stand strong on this. I also read a post here they are not made anymore - false. They are still made and available. Just will cost you near 400 to your door as the dot coms stopped buying them in the thousands to drop costs.
#48
all you really need is to get a full set of factory ford manuals that shops use to fix these trucks... They give wiring diagrams, set by step instructions etc... I didn't know that I wanted to do a rebuild all by myself but I managed to assemble the short block after machining all by myself and a friend or two to help now and then... And I just started on "heavy duty" stuff like rebuilding an engine just a few years back... It's just nuts and bolts and keeping everything organized... and remembering where everything goes back together.
When I get my 351w back into a vehicle I'll have a custom y-pipe made at the local shop... or maybe I'll get creative and weld one up myself... who knows...?>?>?>?
#49
^ Haha, creativity is useful! I've never rebuilt anying bigger than an a 5HPOHV B&S, I replaced the head gasket on an 18HP OHC B&S so tearing a small block is a big jump. We shall see, though...live and learn.
Could a shop rebuild, and install 1.7 RR on the heads to the point were I could just remove and replace the E7's without me having to make any adjustments?
#50
#51
#52
Another question on the heads. There looks to be 3-4 different GT40 heads, not counting the P heads. Some have provisions for the AIR tube and some do not. Also some have the different head bolt hole sizes between 5.0 and 5.8. Whats the part number for 351 GT40s with the AIR tube holes on the back?
#53
When I installed JBA headers on my 302, I made a stand-off long enough to align the brace to where the factory had it on the exhaust manifold. I used a longer grade 8 bolt, or threaded rod (will verify since I can't remember right now) and a length of square steel tubing (for the stand-off). The tubing is against the header flange.
#54
this may or may not help for gt40 and LT questions...
GT40P engine in Bronco - GT40P heads AND GT40P HEADERS that WORK - FSB Forums
#56
rolldog1
03-06-2019 11:41 AM
firerescue9
04-17-2013 10:41 AM
monkei
45
09-25-2008 12:41 AM
f250rollinon37s
04-09-2008 11:13 PM
