The "Ford Death Tick"
all my chevy buddies call it the ford death tick and all the older fords ive ever rode in and some chevies have done it. while driving down the road the engine will tick a little bit when your on the gas and the more gas you give it the quicker it will tick. it sounds like it comes from under the hood on the passenger side but im not real sure. anyway is this my engine knocking? i think i read somewhere that it was something about the valves tapping or something like that?
anyway what causes it and how do i fix it? it normally doesnt bother or concern me because im used to it but today it became a little bit louder so when i got home i checked my oil and it was a little low but not very so i added some too it and it quieted it down a bit. and then on my way home from work it did it again.
im a bit concerned about it because im going out of town with it tomorrow and wanted to know how serrious it was.
thanks for all the help guys
lol sorry " spark knock" thats its real name... it could be an Exhaust Manifold gasket and does it when its hot. I don't want to throw you off to a true issue also. Wait for other replies. Im by no means a ASE guy...
If its the truck in your sig, with just 87000 miles I would be a little surprised if the timing set was wore out. Exhaust leaks can definitely make a sound like you've described, and can be hard to hear when you're under the hood, but very easy to hear in the cab. Not a bad idea to check ignition timing, but in my experience predetonation happens when you're really on it, and the ECU goes full advance.
Mine hasnt done the death tick yet and I hope it won't but I also do take care of my truck so as long as your taking care of your truck well and doing regular oil change and all that you should be ok, I vote for possible leak on exhaust...
