Replace Glow Plugs 06 6.0 How To?
The glow plugs on these are good ones not to many issues
are you getting a cel for GPs or something
you can ohm out each one
and check amps on the right and left banks
If your truck is having a hard time starting up in the morning I would check the FICM voltage
FICM failure is more common than glow plug failure test ficm volts before you buy a bunch of GP
and check FICM when truck cold at startup
I agree with Benny, but here is a thread on the how-to. https://www.ford-trucks.com/forums/1...l#post10498025
What's the reason you are wanting to replace the gp's. Chances are that is not your problem (if you have a problem) We can help you figure it out if you give us a little info.
What code did they find to tell you this? P06xx? Apparently a bad GP module can also cause random cylinder GP codes.
https://www.ford-trucks.com/forums/1...l#post10931325
muddingmcdude
08-19-2007 08:48 PM
