Ford Truck Enthusiasts Forums
-   6.0L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum107/)
-   -   Replace Glow Plugs 06 6.0 How To? (https://www.ford-trucks.com/forums/1096121-replace-glow-plugs-06-6-0-how-to.html)
nomorehoez 09-01-2011 02:44 PM
I know there is a link somewhere to a step by step on replacing the glow plugs in a 6.0 but I can't find it can anyone help me out? thanks... :-drink
powerstroke72 09-01-2011 09:45 PM
Moved to the 6.0L Powerstroke Diesel forum.
BLADE35 09-01-2011 10:34 PM
The glow plugs on these are good ones not to many issues
are you getting a cel for GPs or something
you can ohm out each one
and check amps on the right and left banks
If your truck is having a hard time starting up in the morning I would check the FICM voltage
FICM failure is more common than glow plug failure test ficm volts before you buy a bunch of GP
and check FICM when truck cold at startup
texans 09-02-2011 07:09 AM
I agree with Benny, but here is a thread on the how-to. https://www.ford-trucks.com/forums/1...l#post10498025
What's the reason you are wanting to replace the gp's. Chances are that is not your problem (if you have a problem) We can help you figure it out if you give us a little info.
73woodenbug 03-28-2012 02:30 PM
2007 6.0 # 8 glow plug
I took my truck to a parts store to get a diagnosis after the engine light came on. They said that # 8 is bad.
How do I replace it? Thanks! :-huh
texastech_diesel 03-28-2012 02:49 PM
What code did they find to tell you this? P06xx? Apparently a bad GP module can also cause random cylinder GP codes.
https://www.ford-trucks.com/forums/1...l#post10931325
