starting a 96 psd w/o a key. Help!
You can do that, or what I would personally do is pull the ignition wires and splice the ignition on and get under and start it with a screwdriver. If you dont want to change out the ignition assembly then just hook up the ignition wire to a toggle and the starter to a push button.
Ive done it twice before on two different rigs. Works great, keys are overrated . ALthough I did it to ORVs not tabbed vehicles.
Silvestris
04-08-2013 12:38 AM
jabdmnd2b
04-07-2012 07:50 AM
