Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-23-2011, 09:27 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
Garage is empty, add now
timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.
timmyboy76 seadooya
WVO for me
GUYS!!, I just scored on a greasecar kit.., however, am not stoked, on th locatiuon/setup of the kit. Do not like the fact of relocating the fuel pump, along with, hanging a coiled covered filter, off the alternator housing. Makes the engine bay, WAY to busy, plus, living in CA, think i might have issues, when it comes to smogging it (visual side).
Anyway, i want to use some of the units from the kit...tank, sv100 valves (for purging if possible), coiled filter, but locating it under truck,..etc. SkiSkyJason, has an AWESOME setup on his EX, and from doing ALOT of researching, thats the "design" i'd like to go for....using the CV's on the heads, plumbing the VO lines into the ports, where my FRx is currently located. I read where the RAPTOR 100 fuel pump, has a built in regulator, which will be perfect for me.
I want to run a "seperate" fuel system with the WVO. "rotozuk", also has an awesome DIY wvo kit, also he posted all the fitings needed. SO, McMasterr-Carr will be getting an order soon. One thing that still i cant figure on how it works, is the purge valve, is it necessary. Cant you install the "return" to pre-filter/pump, or not have a return at all.
Guys, thanks for any/all info, STOKED to start this project...
Apologize to post another "forum", but the pics are great, if someone/s is interested in a diy kit...
http://www.thedieselstop.com/forums/...0-f250-201051/
__________________
TIM...PAA#113....plenums inserts, hpx, frx, 50 cent, gauges, trans-coolant-oil DIY by-pass systems, H/H mod, DIY WVO system 156k and counting
  #2 (permalink)
Old 11-26-2011, 09:15 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
check out this 1999-2002 7.3 PSD - WVO Designs Wiki
explains how the system you are talking about works. very simple and cheap to build
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
  #3 (permalink)
Old 12-01-2011, 09:44 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
I have run the stock greasecar kit, with only the addition of a flat plate heat exchanger for 3 years and 75,000 miles with no problems whatsoever.
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #4 (permalink)
Old 12-04-2011, 09:44 AM
timmyboy76's Avatar
timmyboy76 seadooya
Thanks guys.. I had to put the grease system on hold until after the holidays (needing the room in the bed). I decided to use parts from the kit, and build my own. Came out clean, i thought (pics in garage). Being in CA, i took the initiative to "hide" everything, consumed into a box, so when the time comes to SMOG, the system is pretty much a, plug-n-play design...remove it, take truck to get smogged, then return, and install it again. No sense in playing with fire, if it can be avoided..(not passing visual).
__________________
Tags
73, colorado, designs, f250, fuel, greasecar, idi, island, pump, raptor, rhode, sv100, truck, valves, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
