Truck stalls going around right hand corner. Any ideas?
Old 08-23-2011, 12:35 AM
Ak Ford Man's Avatar
Ak Ford Man
Ak Ford Man is offline
I got a 1980 f150 with the 4.9L I-6. the fuel pump has been converted to electric.
When i go around a right hand corner, the truck dies. once u straighten out, it will roll start its self and keep going. any ideas what it might be?
Old 08-23-2011, 04:41 AM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
I remember reading of one owner having that problem (not sure if it was a 6 or V8)........his float level was too high & was flooding the engine cornering.
Old 08-23-2011, 05:29 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
Check to see if the carb is not loose on the intake. My friend's F150 would die turing right and a with a quick left wiggle would keep on running! We found the carb is falling off the intake on turns!
Old 08-23-2011, 06:23 PM
planehunter's Avatar
planehunter
planehunter is offline
Are you sure you have enough gas in the tank? Sucking air as you turn maybe?
Old 08-23-2011, 07:12 PM
billt28's Avatar
billt28
billt28 is offline
Only make left hand turns. No seriously, check the carb for tightness, they're infamous for loosening themselves from the intake manifold. Also check the float level as Ken suggested.
Old 08-24-2011, 12:58 AM
Ak Ford Man
Ive had trouble with is coming loose before. the truck has done it for a long time. I'll check the float.
tallinboy
03-21-2012 09:52 PM
mrmechanic
12-07-2009 04:43 PM
pedrorairez
09-18-2009 05:56 PM
Handegard
08-01-2009 03:17 PM
propflux01
06-04-2009 10:18 PM
Quick Reply: Truck stalls going around right hand corner. Any ideas?
