Front axle outer u-joint
My 96 F250 4X4 destroyed the front right outer axle u-joint. Has anybody replaced one of those without removing the spindle? Or is removing the spindle not such a big deal since I'm already there with hub off? I was hoping to replace it with a couple well placed c clamps and try to do it without hassling with bearings.
on
Don't sweat taking the inner hub and bearing off it's really no big deal, the bearings are caged and all you need to keep in mind upon reassembly is to set the correct preload with the inner bearing retainer nut. I don't see changing the outer U-joint without dismantling all this either, it's just to tight to work.
Ok, all my fears were laid to rest. Got to the spindle and found out that was the worst part. Knocket the crap out of it with a mallet until it gave way. I read about that on this site, so thanks for that. Everything else was straightforward. Discovered for myself there is absolutely no room to replace u-joint while still in truck. Heck I even ruined a new u joint while installing it on the bench out in the open. Pushed the cross right throught the cap. Dont know what went wrong but next one slid right in. Thanks for all the advise.
jollygreen_giant
15
12-08-2010 12:38 PM
jpsage
10-19-2010 01:45 AM
toyota1988
09-24-2003 12:18 PM
