What floor shifter is compatible with FMX transmission ?
Hello everyone , I finally took delivery of my 1956 f100 and I couldn't be happier , since friday I have the biggest . I would like to install a floor shifter but I'm new at this and I need your help . What floor shifter is compatible with FMX transmission ? ( BTW I have a 351 windsor if that helps )
Thanks in advance and please post pics aswell .
I second Lokar. They have a shifter to fit everything else so I would say it's a pretty safe bet. BTW, welcome and get ready for the best (and most expensive) addiction you will ever have!
Hello everyone , I finally took delivery of my 1956 f100 and I couldn't be happier , since friday I have the biggest . I would like to install a floor shifter but I'm new at this and I need your help . What floor shifter is compatible with FMX transmission ? ( BTW I have a 351 windsor if that helps).
Questions: How many holes does the trans pan have? How did you determine it's an FMX since you just bought the truck?
The reason I'm asking is: 351W available A/T's: C4, C6, FMX, AOD, E4OD.
you will quickly find p.o's seldom gets things totally right. I would verify what trans it is before ordering a shifter. as well as anything else you do. verify first, then order. will save you time, money and most of all headaches if you do
I would definantly confirm its an FMX first, it shouldn't take too much effort but will save a lot of hassle in the long run. In fact, I'd double check everything - engine, axle etc as then you know for sure what you're dealing with and can order in the future with confidence. Lots of us have learned this lesson the hard way!!
