Rear brakes feed line
Old 08-21-2011, 12:31 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
I am getting the 9in rear end ready to install. It has part of the rubber line that feeds the junction block on the housing. How do you get it off to replace it? I have tried to put vise grips on it but it does not want to turn. How do you get the brass block off.
Old 08-21-2011, 01:13 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
The original blocks on these trucks were a separate piece and the hose screwed into it. From about the 60's on, the block is permanently crimped onto the hose. You replace the whole thing as an assembly. If your 9" is out of a newer truck, I'd guess that's what you've got.
Old 08-21-2011, 05:06 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
My rear end is out of a 72 ford pickup. So I need to change the whole block?
Old 08-21-2011, 08:09 PM
Doc's Avatar
Doc
Doc is offline
What he's trying to say is that you will get a brand new block when you buy a new hose. They're permanently attached to each other in the factory and sold as one piece.
Old 08-22-2011, 12:05 AM
BlueOvalRage
'Zactly! What you've got doesn't come apart like the original setup did. You get a new block as part of the hose assembly.
Old 08-22-2011, 11:41 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Ach!
You don't: The brass junction block/rubber rear brake hose is a one piece assembly (1968/72 F100 2WD: C8TZ-2282-C .. Rear Brake Hose).
The block has a hole in it, the rear axle vent passes thru the hole, threads into the rear axle.
T-wood
02-17-2018 05:48 PM
cb93cobra67
03-21-2011 03:17 PM
wreedZ71
2004 - 2008 F150
12-29-2010 07:46 AM
65vamonster
09-30-2004 12:19 AM
Quick Reply: Rear brakes feed line
