Rear end vent hose
Old Dec 28, 2010 | 06:14 PM
wreedZ71's Avatar
wreedZ71
Rear end vent hose
Hey I need to change the fitting the rear end vent hose attahced to, to make sure it is not plugged. it seems to be on the same block the brake lines run thru. if I removed the vent nipple, this will not mess up the brakes, correct?
Old Dec 29, 2010 | 06:35 AM
Twinsdad98's Avatar
Twinsdad98
Why don't you just blow it out with some brake cleaner? No, removing the vent nipple has nothing to do with the brakes. The bracket holds the lines, but they are separate systems and you will not effect the brakes in any way.
Old Dec 29, 2010 | 07:46 AM
wreedZ71's Avatar
wreedZ71
thanks!!!!!!!
Greg5OH
Nov 12, 2015 07:11 PM
Whitey Ford
21
Aug 18, 2015 04:42 PM
Skalywag
Jun 2, 2014 08:50 PM
BDawg171
17
Apr 8, 2014 01:09 PM
burner718
Jan 11, 2008 01:07 PM
