Engine Swap 5.4 to Newer 3v 5.4 - Advice/Help
Folks,
I have a 2000 F-250, 5.4, 4x4. The valve train sounds like a diesel at start-up and with 220K on the engine I am thinking about putting a new engine into the truck. Instead of going back with a used 2000 engine I was thinking of stepping up to a newer 3v.
I can get a 2008 used engine, complete, for around $2000. It is the 3v and should produce more power and better economy, I would think. That being said, will it work without major mods? Will it bolt up to my existing tranny which is working good? I know I would need an ECM but those are cheap. Are the motor mounts in the same place? Will the exhaust manifolds fit?
I am wondering if it is worth the trouble for whatever gains I will get. Just let me know y'alls thoughts before I head down the slippery slope.
Thanks in Advance,
Jason
Thanks in Advance,
Jason
If you are not comfortable with custom fabrication and custom tuning along with lots of little annoying issues that are going to pop up-My suggestion is to NOT even attempt to swap to a 3V. If you use phaser lockuots, then the power advantage of the 3V is pretty much gone, and you're not accomplishing anything.
JL
JL
