Y pipe help needed!
Old 08-19-2011, 09:45 AM
rdunagan's Avatar
rdunagan
rdunagan is offline
Y pipe help needed!
how would yall go about getting the up pipe and y pipe out? mine started leaking yesterday and i dont have alot of money to spend on it right now so i need to do it myself. its one of the things that i would rather pay someone to do but just dont have the money. whats the easiest way to pull it and put new one on?
Old 08-19-2011, 11:19 AM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
Remove the turbo, and remove the clamp on the EGR cooler if its still there...
Remove nuts to the manifolds, and the whole thing will slide right out.
Old 08-19-2011, 12:37 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
so pull it from the top? and do i need to split the up pipe and y pipe or leave them together
Old 08-19-2011, 12:59 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
You can leave them together. It's a little squeeze to get it out but it will come. Move or remove the FICM too.
Old 08-19-2011, 01:08 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
cool. how long does this take if i can get the turbo out in say 30 mins. ive pulled one that fast before. because im leaving tomorrow to go to the lake for the weekend so if i can do it in about 3 hours ill knock it out today
Old 08-19-2011, 01:32 PM
npccpartsman
If you have the y-pipe bolts at the manifold loose or out and turbo out--about 30 seconds or less to pull the y-pipe and another 30 to put it back in....turbo reinstall time is on YOU--LOL. 3 hours should be more than sufficient. My crippled azz can do one almost that fast.
Old 08-19-2011, 04:07 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
haha ok cool sounds good. im going to spray them tonight so hopefully it will work
Old 08-19-2011, 07:40 PM
wulfman's Avatar
wulfman
wulfman is offline
rdunagan i could not pull the Y pipe still connected to pass side pipe was just not enough room for it to come out I had to split the two then the Y pipe lifted right out. if you can do it I would like to hear how it went.
Old 08-19-2011, 10:59 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
ill let ya know in the morning when i tackle it
Restlesswildman
05-09-2016 10:56 PM
2006powerstroke90
12-03-2014 01:40 PM
ATE88
6.4L Power Stroke Diesel
10-16-2014 02:47 AM
Diesel cat
15
09-16-2014 09:50 PM
queen of spades
05-30-2014 07:50 AM
Quick Reply: Y pipe help needed!
