Info and parts on an 1949 Dump Truck
Old 08-20-2011, 04:45 PM
kmcisaac1985's Avatar
kmcisaac1985
kmcisaac1985 is offline
Post Info and parts on an 1949 Dump Truck
My father has just bought a 1949 Ford Dump Truck. It needs the condenser and points, and the exterior rubber kit. So far, we're running into a virtual brick wall when looking up parts.
It is a 1-ton truck, which from what I found is an F4? Any information would be greatly appreciated.
Old 08-20-2011, 06:29 PM
mtflat's Avatar
mtflat
mtflat is offline
Your picture shows a 42-47 truck. They weren't F-series, just went by weight rating - i.e. - one ton.
The frame looks like a one ton frame.
48-50 had horizontal grill bars where your's are vertical. Lots of other points too.
Your serial number will be something like 799T 123456 or 71HT 123456
Old 08-20-2011, 06:32 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
Cool old truck, but you will probably have better luck finding parts for it if you look for the right stuff. Your truck is a 1942-47, not a '49. The body style changed in '48. The good news is the cab is a carryover from the 1940-41 trucks, so finding soft parts like exterior rubbers, window channel parts and weatherstripping will be easy, as they are readily available. Check with Bob Drake. Engine and ignition parts will be available locally from your neighborhood NAPA store.
Old 08-21-2011, 06:57 AM
kmcisaac1985
After Googling an image of a '47, we could instantly see the difference.
For serial numbers, I found an article online stating about how the serial numbers were coded on the '49 - '51 ( 1949 - 1951 Ford Truck US Canad ). Would there be something similar for pre-'49 models? As mentioned the 799T and 71HT codes, guessing the 7 was year and T was Ton (like the F-Series), but as for the 99 and 1H, is there a way to tell the engine type (such as V6/V8, horsepower, etc)?
Thanks
Old 08-21-2011, 09:15 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
You can get the tune-up parts, prolly the weatherstrips, and a lotta other stuff from Dennis Carpenter, located in Concord, North Carolina.
Canadian resident: Call Carpenter @ 704-786-8139, order a 1932/47 truck reproduction parts catalog, it's free / email: info@dennis-carpenter.com
A closer source to NL would be Mac's Antique Auto Parts (macsautoparts.com) located in Lockport NY. But Carpenter has much more stuff.
For original literature, try: faxonautolit.com
1942/47 1/2 tons (114" wheelbase) are known as Commercials, anything larger are just called Trucks.
The F Series was introduced in 1948.
Old 08-21-2011, 11:54 AM
mtflat's Avatar
mtflat
mtflat is offline
For serial numbers, I found an article online stating about how the serial numbers were coded on the '49 - '51 ( 1949 - 1951 Ford Truck US* Canad ). Would there be something similar for pre-'49 models? As mentioned the 799T and 71HT codes, guessing the 7 was year and T was Ton (like the F-Series), but as for the 99 and 1H, is there a way to tell the engine type (such as V6/V8, horsepower, etc)?
Thanks
Those are the engine codes - althought I screwed up. 47 had the G series 6 cylinder. 48 and later had the H series 6.
99 was the V8 designation. 1G was the 226 ci flat six designation.
acl9865
1947 and Older Ford Trucks
04-28-2017 02:39 PM
Carolina 52
09-27-2012 08:47 AM
51PanelMan
08-21-2010 12:35 AM
Heritage04
12-31-2009 08:43 AM
Bubble Boy
16
12-12-2007 10:51 PM
Quick Reply: Info and parts on an 1949 Dump Truck
