Starter going on 88 F150
I think my starter is going on my 88 F150. If it conks out on me before I replace it and I'm stranded, what is the procedure to start my truck with a screwed-up starter. I've seen guys use a screwdriver or something to get the vehicle going. Can anyone tell me how to start it in an emergency?
Park on a hill. If the starter is really gone, you've gotta push or roll start it. The guys that use a screwdriver across the relay terminals have either a bad relay or a bad starting circuit.
What symptoms lead you to believe it's the starter? What engine? What transmission? Why don't you wanna just replace it now BEFORE you get stranded?
What you have seen is people jump the solenoid, not the starter itself. The solenoid is located on the drivers side firewall and connects the starter to the big fat red positive battery calbe when you start your car.
You want to make sure that indeed your starter is on its way out, not the solenoid. If it is only the solenoid, that is easy to change. Pull the old one, put the new one and ensure good contacts. Done. Can do that in 10 minutes, standing up, not even getting dirty.
If you want come back on here and describe the symptoms a bit better. There are hints that point to the solenoid while others do point to the starter.
The starter sits on the flywheel which is in the back of your engine. Once it is gone there is nobody getting you home, except AAA.
Cheers, Geroge
Cheers, Geroge
My truck would click the solinoid and then 2-3 seconds later the starter would turn. Found it was a bad connection w/ the wire on the starter. There could be a lot of possiblities other then the starter, time to diagnose.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
That truck had the battery ground cable running almost 6 feet and bolted to a starter mounting bolt. Do yourself a favor like I did and eliminate a bunch of problems. Get about an 18 inch length of #2 cable and ground the negative side of your battery to the alternator bracket. Then get another length of #2 cable and replace your positive cable to the starter solenoid. I even replaced the one from the solenoid to the starter with #2 cable. Mine was slow turning over and would sometimes hesitate to turn over. My radio would loose its memory when this happened because it dragged the voltage so low. I have not had a problem since I done that almost a year ago. The factory cables that came with the truck are barely big enough to carry the electrical load of that starter. Good luck!!
If for some reason you get stranded, you can hit the starter fairly hard with a screwdriver or other metal object of length and repeat the start. Should fire up. However, this is only good untill you replace the starter. Tried it on several friends trucks. Good luck.
I've got an 88 with a 300 and the starter was having problems cranking. I picked up a starter at advance for about 35 bucks. It was so easy to change. If you've got the money, give it a go. It may also be timing. My mom's 85 lincoln jumped timing years ago due to a bad timing belt or chain or something and it world crank really slow due to the messed up compression. But I'm guessing it's the starter. The guy at the auto parts store told me it was fluid that was leaking that got in the brushes.(I had a steering box seal blow on me and get all over the place) Hope I could help.:+
If it's the original starter and your in a snow state where they put salt on the roads in the winter, then it's a good idea to change the starter. I did mine last winter on my '91 F250 300cid 6cyl. It had been kicking out sometimes and got to where it didn't want to start. Dropped it out and took a good look. Half the zinc plated cover on the relay on the starter was gone. The relay was out in the weather. The actually starter case was starting to flake off in layers from the corrosion.
The salt corrosion also ate a brake line up. A few months later I was hauling some limbs on a trailer. Backed in to the pile and the pedal goes to the floor. Brake line had simply fell to pieces over several feet.
