Fuel Filter Change- No Start (Any Suggestions)
I just changed the secondary fuel filter (under the hood) Went to start the engine to purge the air before changing the primary filter (on the frame rail). I usually turn the key on until the pump stops then crank on 5-8 sec intervals until it starts. Ususally takes three to four cranks for the secondary filter. So far I have run the batteries down and only got it to fire a couple times for about 5 seconds so somehow there is air in the system which is not purging this time. I took the filter cap off and made sure the filter was fitted properly and at that time the fuel bowl was full. Any suggestions?
The purge method specified in the owner's manual is to cycle the key *without starting* the engine, which causes the fuel pump to run and push fuel through the system which causes the air in the system to be pushed back to the fuel tank via the fuel return line.
If you've pushed air further into the fuel system, it may require purging from either the low of high pressure sides of the system with the appropriate tools.
I agree with wp6529, best to not crank the engine until the system is purged. Also the procedure is to change both filters at once and then purge. If you purge the secondary filter and then replace the primary, you're still going to have to work the air through the primary and then the secondary before starting the engine.
I've found that following the owner's manual isn't enough to get the air out before cranking. On two occasions I've followed the book to purge the air then cranked the truck and had the truck stumble and die and be a pain to restart.
I now cycle the key for a few minutes. If you listen closely you can actually hear the air going back to the tank and tell when it is all out.
