Steering wobble cure? - VIDEO
Ha! Ha! It is a great video for sure. It shows the ease of installing shocks, and stabilizer. I loved the ingenuity of using the wrench for the space on installing the SS as well. And doughnuts? Come on! win! win!
on
Epic -
So the dual SS kit. You think that was the ticket? Is the shock upgrade necessary? Geez, I thought they rode pretty nice on my test drives. Lots of upgrades to do. At least I'll have 10 months to get it dialed in before a Rocky Mountain Road Trip with the family...
Thanks,
Thanks,
i just installed my Dual Stabilizer. A 12 gauge shotgun shell was my spacer - gives a little more clearance than the wrench (so the boots don't rub so bad). Took the truck to the infamous "death wobble" testing grounds and it definitely helped, but did not cure. I would say it reduced the DW to about 1/2 of what it was.
All is good!
All is good!
I have had my Rancho Dual Stabilizer kit on my 2011 F-350 now for about a year. I have a great place to test how well this works here in Denver. East bound C-470 to I-25 North. It is a elevated LH fly over with a pretty "aggressive" expansion joint. I went over it today and and almost lost control of the vehicle at the posted speed limit. Could it be that my shocks are shot after 1 year like my OEM shocks were? What else are guys using to fix this problem? I put Bilstein's on about 6 months after i owned it as the OEM shocks were shot. I may have to look into one of their stabilizers. Any thoughts would be much appreciated.
on
If I had to guess, I'd say the stabilizers control most of the side-to-side motion. The shocks control the up and down and likely have a small effect on the wobble. All together they do a good job of dampening unwanted motion.
All is good!
All is good!
#29
A while back on this site I saw some lab R&D testing where they put the shocks and stabilizers (I think) under durability testing. The shocks were mounted in a device which simulated road action. I didn't watch each video clip (there was about 6 on one page). From what I saw the rubber bushings were a trouble spot. Especially after many cycles. Even if the shock was good the durometer on the rubber was too soft allowing enough instability that the dampening effect of the shock was compromised. Especially at the end of the durability run. They were really soft then. I wonder what the results would be if Polyurethane or solid impregnated bushings were installed??? With the Rancho or like the Bilsteins I have Ill bet it would virtually eliminate any remaining deflection left after junking the OEMs. Any one tried that yet?
#30
on
jrcochranusa
05-12-2016 06:33 AM
