8 volt battery or covert to 12
I am thinking of putting a 8 volt battery into stock 6 volt system instead of converting to a 12 volt. I was wondering if anyone out there has done this and if I could get an help on what i need to change if i run the 8 volt. Im being told that the engine will turn over much faster and my lites will be brighter , which are my main issues at this point. Does anyone out there make a 6 volt halgen headlite.
on
If slow cranking is your main complaint, the problem may be in the starter. These didn't ever crank over fast tho, they were famous for a low growl, slow spinning start. Nothing like modern cars. Have someone who is familiar with flatheads listen to it. Remember, these trucks came with a hand-crank and it was not that big a problem to start them that way (I'm told, anyway). They don't need fast cranking to start.
8v is about the worst solution IMO. Almost as much work as 12v but none of the benefits.
HkyswiM
11-16-2011 04:24 PM
