360 hard to start when hot
Haven't been driving the F100 enough... but now that it is summer time, I found that after driving the truck, and shutting it off, it is very hard to restart.
The engine does not run hot, and the starter cranks the engine over very well. It usually takes cranking for a long time, while holding the gas pedal to the floor, in order to start back up.
When the engine is cold, it starts right up.
Any advice?
Any advice?
Yes the intake and exhaust manifolds are all original cast iron. And it does seam like it would be more carburetor related.
The one inch spacer insulator sounds like it would do the trick.
It makes me wonder why this truck would boil the gas out of the carburetor? The engine does not run hot.
Sounds like a "Heat Soak" problem. Ford did make a 1-inch metal spacer for their 2-Bbl carbs.There might also be some thick (1/4") aftermarket gasket type spacers available too. If you have the heated metal spacer with the heater hoses connected to it just bypass the spacer during the summer by running the hose directly to the heater.
If it ran good otherwise, put the timing back where it was and check your batt cables and grounds...old, corroded cables will cause hard hot starting due to heat and resistance. If you don't have the stock carb spacer plumbed to the heater hoses, use a phenolic spacer or make yourself one out of hardwood...that'll work, too. Carb heat soak can show up when it gets real hot...as in the weather.
"It usually takes cranking for a long time, while holding the gas pedal to the floor, in order to start back up.
When the engine is cold, it starts right up."
Im a little confused as to what you are saying here.... asuming your holding the pedal to the floor, does that mean it acts flooded? if thats the case, and you had an electric choke, the choke could close to fast after shutoff and make it run really rich and hard to start...(damn those electrick chokes) but if you have to pump it, i would stick to the gas boiling theore... if your timing is advanced too far it will turnover and then stop randomly for a second due to pre-ignition, but you usually only have to back the timing off a couple degrees if thats the case...
