WATER TEMP GUAGE BAD?
O.K. here I go, where is the sending unit located for my water temp guage? I have a 95' 4.9l auto 2 wd w/air....is it on the left side down on the block sorta behind the oil filter? yes my guage is acting wierd and so is the fuel guages. any help would be nice and most likely a repeat. I'm not sure on how to search.
Ground the block water temp sensor terminal and see if your gauge goes full scale. If all of the gauges are giving you trouble it could be a bad ground for the cluster. The OBDI port is located on the driver's side fender near the firewall. Go to fordfuelinjection.com for info on pulling the codes.
regards
rikard
regards
rikard
stangbanger
10-02-2008 09:14 PM
1957F100
10-11-2007 07:23 PM
