new u-joint?
Umm, squeaking, and then it goes away with speed. When it gets worse you get a vibration. You could also hear clunking. And probably the worst symptom of a bad U-Joint is not being able to move because you realize you threw your driveshaft.
To check it out get under the truck (in neutral I think? So chock the wheels!!) and see if you have some slop in the joint by moving the driveshaft. Sometimes you may be able to just tighten up the clamps on the yoke if they came a little loose or got some play. If the joint is bad you will need to replace it.
Block the truck (on level ground if possible), set the parking brake, put the truck in neutral (without motor running) get under it and shake the crap out of the driveshaft near each joint, that should pinpoint which one is bad.. Squeeking is a sure sign at least one of them is shot!!
Just to be honest with you, if you find one bad one the chances are the others are not far behind..
I've replaced the one closest to the rear diff many times, but the one near the transfer case only once. Must be due to the rear one seeing more mud and road grime. But yes, low speed squeak, brown dust, clunking, vibrations, even a snap sound when going from reverse to drive are all indicators of a bad U-joint.
You can shake the crap out of a drive shaft and still not see a bad U-joint. Believe me, it's my business. Check to see if it's the front or rear, pull that drive shaft out, work the joints back and forth and see any odd movement: REPLACE... As for just tightening straps / u-bolts, don't do it unless loose. Those straps / u-bolts should only be tightened to 25 pounds maxed. Over tightening the straps / u-bolts can and will distort the bearing caps!!! Another area to check is the centering ball / bearings in a double cardan joint. Lube all joints, even the ones that don't have zerk fittings.
that really doesn't need to be done as long as you keep the drive shaft itself in phase. The diff yokes have very little to no effect on drive shaft orientation. But if it makes you happy go with it....Good luck
Milwaukee1979F150
07-31-2008 11:16 PM
