2005 4x4 Excursion, new ball joints... and the zerk fitting dilemna
I know this has been discussed a zillion times, but I didn't find any pictures on just "how to do it". So I made some yesterday (took the pictures that is)
I recently replaced my front end ball joints, and some other items and the tech that did the job was not eager to go get me the 90° zerk fittings for the upper ball-joint. Nor, did he offer to put in a standard zerk (one BJ was missing a std. zerk right out of the new box) from his tool box. No worries, I told'em I'd take care of it... as it was late, and we both wanted to go home (he was doing this work "after hours"). AND, I had already made a run to the local auto parts store for new front calipers. Oh joy! I wasn't going back that same night.
SO....
I read up here how the 90° zerks are such a close fit... there's some grinding involved. I thought, "grinding"?? Thinking to myself, that the zerk fitting probably doesn't have a whole lot of meat to grind on... and I'm surely not going to grind on my axle/u-joint knuckle! So, after further reading I saw posters talking about the zerk. So off into the garage I went, with spare zerks of course!!
I put them onto the stationary belt sander and ground until I thought I'd poke through, into the grease path. Nope... keep grinding. Hmmm... it took a while, and soon enough I was into the grease path. But, I was able to remove A LOT of material from the dome of the zerk. I didn't need much, as the clearance of the zerk to knuckle was just enough to shave the zerk down a bit (and thankfully not break it off when I tested how close it was). This "testing", put a small grind mark into my knuckle so now I could see where it was just that close.
Here's a comparison to the new zerk, and the ground down zerk;
Once installed, I made sure at slow hand turning speed... that the zerk didn't hit the knuckle anymore and had a bit of 'extra' room. NOT MUCH! But it had some, which was more than before. I then road tested it to see if I could get the knuckle to contact the zerk, or worst case... risk breaking off the zerk in the ball joint. Hey, I'm a risk taker! And no worries... it was all good to go!!
Here's that clearance I speak of (So close, but still plenty of room - you can see the previous grind marks in the knuckle);
I hope this helps any future Zerk Goers down the road. I could have just put the std fittings in, and bought the 90° fitting for the grease gun (as I read some do this method)... but, then I'd have to carry it around in my glovebox for those days I stop at Jiffy Lube. Now, anyone I have service the vehicle can access the BJ Zerks. Simple enough!
I also thought about the flush mount zerks, but those too... need a special needle grease gun attachment. And that would have to be made into a 90° tool too. Not very "user friendly" like a simple zerk as shown. Plus, I've read where many owners are using their 4wheel drive with NO PROBLEMS of clearance of knuckle and zerk. A no-brainer for me!
Enjoy!
SO....
Enjoy!
This is what I used to be able to grease my upper ball joints, makes like a lot easier. Ford Truck Enthusiasts Forums - RobRoss's Album: Grease Gun Fitting - Picture
... I like simple solutions, and a touch on the belt sander did it for me.
