stalling problem grrrrrrr
hello all have a ford 1990 econoline camper with a 460 fuel injected moter start it up runs great get 10 to 20 mile down the road and starts cuting out and then stalls and wont fire or restart and 30 to 45 min later u get in and it fires up and runs like a top again for anther 10 to20 mile i need help lol im lost anyone got some ideas if so id greatly app all help or ideas ty have a great day bryan
I had an issue a while back that might help. I could start my truck and it would run fine but wouldn't get past about 20 mph. Mechanic couldn't figure it out after buying a $5000 piece of equipment. Once I got it home and messed around with it, I found that the in-tank fuel pump was bad. In the fuel pump there is a dime-sized diaphragm that had a crack in it and would leak. That was causing the problems I had. Unfortunately, in this situation, the only way to make sure that was the problem was to buy a fuel pump and install it.
fordfuelinjection.com is suspended has a link that provides you instructions for retrieving codes for free. Unfortunately, it appears the site it temporarily down.
As other members stated, fuel or electrical problems could be the culprit. Try to retrieve codes as someone may know the method, since I cannot remember how. I have a Equus code reader that tells me without having to count flashes and could lead to wrong codes.
Just checked again, the site is back up. Here's the link..
Ford Fuel Injection » How To Run a Self-Test
stretchinline
01-13-2008 04:18 PM
mooner
11-30-2004 04:07 PM
