stalling problem grrrrrrr
Old Jul 26, 2011 | 10:20 AM
bsmick69's Avatar
bsmick69
hello all have a ford 1990 econoline camper with a 460 fuel injected moter start it up runs great get 10 to 20 mile down the road and starts cuting out and then stalls and wont fire or restart and 30 to 45 min later u get in and it fires up and runs like a top again for anther 10 to20 mile i need help lol im lost anyone got some ideas if so id greatly app all help or ideas ty have a great day bryan
Old Jul 26, 2011 | 11:42 AM
WoodGrain's Avatar
WoodGrain
Does your van have a computer? Maybe you could have it scanned for an error codes. Other than that I have no idea dude. Sounds like gremlins to me.
Old Jul 26, 2011 | 12:00 PM
RIKIL's Avatar
RIKIL
I had an issue a while back that might help. I could start my truck and it would run fine but wouldn't get past about 20 mph. Mechanic couldn't figure it out after buying a $5000 piece of equipment. Once I got it home and messed around with it, I found that the in-tank fuel pump was bad. In the fuel pump there is a dime-sized diaphragm that had a crack in it and would leak. That was causing the problems I had. Unfortunately, in this situation, the only way to make sure that was the problem was to buy a fuel pump and install it.
Old Jul 26, 2011 | 12:24 PM
imabaka's Avatar
imabaka
The pip in the distributor or the ignition module will cause this problem.
Next time it does it see what u don't have fuel pressure( with a fuel pressure gauge) or spark.
Old Jul 26, 2011 | 02:10 PM
timbersteel's Avatar
timbersteel
fordfuelinjection.com is suspended has a link that provides you instructions for retrieving codes for free. Unfortunately, it appears the site it temporarily down.
As other members stated, fuel or electrical problems could be the culprit. Try to retrieve codes as someone may know the method, since I cannot remember how. I have a Equus code reader that tells me without having to count flashes and could lead to wrong codes.
Old Jul 26, 2011 | 02:12 PM
RIKIL's Avatar
RIKIL
cached version isn't as pretty but works - Ford Fuel Injection
Old Jul 26, 2011 | 05:57 PM
timbersteel
Just checked again, the site is back up. Here's the link..
Ford Fuel Injection » How To Run a Self-Test
Old Jul 27, 2011 | 11:29 AM
bsmick69's Avatar
bsmick69
well thanks ll for the input
Old Jul 27, 2011 | 11:48 AM
Kemicalburns's Avatar
Kemicalburns
the TFI module thats mounted on the distributor has a tendancy to fail when it gets warm and will behave just as you described.
Old Jul 27, 2011 | 12:01 PM
Slip ford man's Avatar
Slip ford man
Been having the same problem, be sure to up-date this thread when a cure is found.
Old Jul 27, 2011 | 01:38 PM
timbersteel
Imabaka and Kemicalburns mentioned a good point. If the TFI is mounted on the distributor, this may be the culprit. The TFI was mounted later to the driver side fender under the hood to keep it away from the stress and heat of the engine.
Old Jul 27, 2011 | 08:13 PM
bsmick69's Avatar
bsmick69
thanks for all the input had a guy came over today and looked at it and thout it might be the same thing ya mine isent on distributar mine is under the aux batt
dynobill
Aerostar
Feb 26, 2018 07:15 PM
stsscott
Jan 9, 2014 11:54 AM
stretchinline
Jan 13, 2008 04:18 PM
mooner
Nov 30, 2004 04:07 PM
