2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Doesnt sound right to me
Old 07-20-2011, 02:26 PM
KOMPLEX1's Avatar
KOMPLEX1
KOMPLEX1 is offline
Just took my 2007 Expedition into my mechanice for a loud rattle coming from the front of the motor at every start up, a surging that to me feels like a misfire, and a lack of power. All have been getting worse. He told me it was 6 quarts low on oil. This car has hydraulic lifters, hydraulic cam, and hydraulic timing. Its always had oil pressure and no check engine lights. Ive even tried to pull history codes(Snap On scanner) and nothing. Being that low on oil the lifters should collapse and not open the valves timing would be screwed and the car shouldnt run at all. Someone please tell me if Im correct and being fed some BS.
The only thing I can think of is that the last guy to change my oil didnt put oil in the car. There are no signs of leaking and the truck doesnt smoke at all.
Old 07-20-2011, 08:48 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Hydraulic lifters- Nope the engine does not have any!!! Its SOHC and uses lash adjusters!
Hydraulic Cam-Nope that only comes into play with pushrod engines
Hydraulic timing-Yes it does have two cam phasers which could explain your surge!
The gauge in the dash is fake so do not go by that to judge oil pressure. It is preset to stay at the same mark as long as the sender gets 5 psi oil pressure.
Old 07-20-2011, 09:28 PM
KOMPLEX1's Avatar
KOMPLEX1
KOMPLEX1 is offline
Being 6 quarts low on oil would the motor even run? One quart wouldn't be enough to maintain any consistent oil pressure right?
Old 07-21-2011, 05:39 PM
berry1234's Avatar
berry1234
berry1234 is offline
No oil light came on?
Old 07-22-2011, 11:50 AM
KOMPLEX1's Avatar
KOMPLEX1
KOMPLEX1 is offline
No lights at all!
Old 07-22-2011, 12:05 PM
berry1234's Avatar
berry1234
Were you in warranty? Sometimes dealers will say it's your fault so they don't have to deal with Ford on warranty claims.
Old 07-22-2011, 12:06 PM
KOMPLEX1's Avatar
KOMPLEX1
KOMPLEX1 is offline
Out of warranty.
Old 07-22-2011, 12:22 PM
berry1234's Avatar
berry1234
The rattle on start up is the timing chain tensioners rattling from the gaskets being blown. You need to replace the tensioner gasket and arms. This is not from being low on oil. It is fairly common on the 5.4l motors and happened to mine at 50K and I change/check my oil regularly.
This was covered under my 5/60 power train warranty.
Old 07-22-2011, 12:25 PM
KOMPLEX1's Avatar
KOMPLEX1
KOMPLEX1 is offline
They filled it with oil and the noise of just about gone. I'm still nervous that there is other damage done to the motor from running low on oil. I'm gonna sell it and buy a new F250.
Old 07-22-2011, 12:33 PM
berry1234's Avatar
berry1234
Sounds like a good plan. Try Car Max. I have had good luck with selling cars to them. Fair prices in this economy and no hassle.
cruisemon
1983 - 2012 Ranger & B-Series
18
09-06-2008 09:23 AM
5.0stang
10-28-2007 11:09 AM
hoxiii
12-03-2006 09:28 AM
John Boyd
16
11-21-2005 02:32 PM
Frank
01-04-2000 02:51 AM
Quick Reply: Doesnt sound right to me
