IP differences
I recently asked the same question of a pump re builder and he told me the only difference is the throttle linkage
The cold idle solenoid and throttle linkage are different for sure. The throttle linkage won't allow the cruise control cable to connect to the throttle cable. The cold idle soleniod seta up alot higher. If you try to use the cold idle solenoid with a throttle linkage from a regular truck, the throttle linkage won't even come close to touching the cold idle solenoid.
Not going to bet money on this, but i was thinking the engines used by IH were governed at 3k and the ford used ones were 3300. I had no idea about the external differences.
LARIAT 85
17
02-27-2022 04:02 PM
Samstha
09-08-2009 03:12 PM
GeneStoner
06-18-2004 10:33 AM
Ol Rudy
02-13-2004 02:11 PM
