warning chime not properly working
Old 07-23-2011, 07:58 PM
imabaka's Avatar
imabaka
imabaka is offline
Ok usually I can figure this stuff out but this one has me baffled. The chime goes off when I first turn the key on for a bit and then goes out no problem there. But when I leave the key in and open door it doesn't go off nor when I leave the headlights on with out the truck running and door open does it go off. My dome light works properly, my head light switch isn't melted, and on the chime box its self I have a wire that powers up when I turn the lights on.
Am I missing the ground from my door switch ? I found one broken wire in the door wiring it self and that fixed my passenger window switch not working.
I realize most people don't want this chime to work, but I forget to turn headlights off sometimes and I don't want a dead battery or to lock my keys in. Stuff not working the way its suppose to drives me nuts.
Thanks for the help, and sorry if this came typed out weird since I did it on my blackberry.
Old 07-24-2011, 12:46 PM
imabaka's Avatar
imabaka
imabaka is offline
Well I figured it out. I found a wiring diagram in my service manuals. I found out that the red with a pink stripe wire should be powered when the door was open.
This wire wasn't powered up so I pulled the door jam switch and swapped it with the one from the passenger side. And the chime started going.
One less thing to fix now
Old 07-24-2011, 12:51 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Glad you got it working, thanks for the update...
wharthog
1999 to 2016 Super Duty
10-20-2017 08:55 PM
bigfinn
27
03-03-2012 08:44 AM
Andrew010
6.7L Power Stroke Diesel
02-14-2012 09:33 PM
1936JDB
10-15-2011 07:44 AM
daniele
1983 - 2012 Ranger & B-Series
08-13-2004 07:59 AM
Quick Reply: warning chime not properly working
