2006 F150 Transmission problem?
I have a 2006 F150 4x4 with the small block V8. It has an automatic transmission with the push-button overdrive button in the end of the shifter. 130,000 miles.
Driving uphill, it has developed a loud clatter. It's not quite a grinding sound and not quite a rattle. I believe it's in the transmission, but I'm not sure.
EDIT: After reading the forums, it appears that this is the IWE Solenoid.
Last edited by Apollo-11; 07-25-2011 at 12:24 PM. Reason: Found answer to question on forum
2006FOMOCO
10-15-2023 06:12 PM
06, 2006, 46, f150, ford, grinding, issues, problem, problems, slip, slipping, transmision, transmission, transmition, truck
