possible fuel problem emerg. shut off
thanks
FPDM connector disconnected.
Key in ON position.
Measure the voltage between:
( + ) FPDM PWR Connector Harness Side and ( - ) FPDM Connector Harness Side GND
Is the voltage greater than 10.5 V?
Yes
For Ford GT, To check the FPM circuit,
GO to KB14 .
For all others, INSTALL a new FPDM.
No
GO to KB4 .
KB4 CHECK POWER TO FPDM
Key in ON position.
( + ) FPDM Connector PWR Harness Side and ( - ) Ground
Yes
REPAIR the open circuit.
(Open FPDM ground circuit)
No
Key in OFF position.
No power to the FPDM
For F-150,
F-Super Duty,
Expedition, and
Navigator, GO to KB10 .
For all others, GO to KB5 .
KB10 CHECK THE FUEL PUMP FUSE
Note: These steps are for applications with FPDM PWR relay integral to the PDJB.
Check the FPDM power supply relay fuse. (located on the PDJB).
Is the fuse OK?
Yes
GO to KB11 .
no
INSTALL a new fuse.
CHECK the associated circuits for a short to ground before installing the fuse.
KB11 CHECK POWER TO IFS
IFS connector disconnected.
Key in ON position.
( + ) IFS Connector Harness Side FPDM PWR-A and ( - ) Ground
Yes
GO to KB13 .
No
GO to KB12 .
KB12 CHECK THE FPDM PWR CIRCUIT FOR AN OPEN BETWEEN THE IFS AND PDJB
PDJB connector disconnected. (connector with FPDM PWR circuit)
Measure the resistance between:
( + ) IFS Connector Harness Side FPDMPWR-A and ( - ) PDJB Connector Harness Side FPDM PWR - Pin 3
Is the resistance less than 5 ohms?
Yes
CHECK the fuel pump fuse.
If OK, INSTALL a new FP RLY/PDJB.
No
KB13 CHECK THE IFS FOR AN OPEN
( + ) IFS Connector Component Side FPDMPWR-A and ( - ) IFS Connector Component Side FPDMPWR-B
Yes
(Open FPDM PWR circuit)
No
INSTALL a new IFS.
KB14 CHECK THE FPM CIRCUIT FOR AN OPEN IN THE HARNESS
PCM connector disconnected.
( + ) FPDM Connector, Harness Side FPM and ( - ) PCM Connector, Harness Side FPM
Yes
GO to KB15 .
No
KB15 CHECK THE FPM CIRCUIT FOR A SHORT TO POWER IN THE HARNESS
Key in ON position.
( + ) FPDM Connector, Harness Side and ( - ) Ground
FPM
Is the voltage less than 1 V?
Yes No
GO to KB16 . REPAIR the short circuit.
KB16 CHECK THE FPM CIRCUIT FOR A SHORT TO GROUND IN THE HARNESS
( + ) FPDM Connector, Harness Side FPM and ( - ) Ground
Is the resistance greater than 10K ohms?
Yes
GO to KB17 .
No
KB17 CHECK FOR FPM OUTPUT FROM THE FPDM
FPDM connector connected.
Key in ON position.
Note: It is OK for the voltage to cycle below this range and then return within range.
( + ) PCM Connector, Harness Side FPM and ( - ) Ground
Is the voltage between 0.02 V - 1 V?
Yes
INSTALL a new PCM. REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) .
No
INSTALL a new FPDM.
Hope any of this helps. If it turns out you need a new one check Tasca Parts they might have one cheaper than the dealership.
thanks
