bump 4wd on/ bump 4wd off???
Hi guy got a weird situation for yous, For months I have had a vibration that starts with bumps, and stop after bumps. tonight when It started I turned on esof 4wd on , and it stopped, every time. I am pretty sure that I have a bad u-joint on the front drive shaft, That would explain the the vibration. But why does the front drive shaft start a stop spinning after bumps? The 4wd light only comes on when the esof **** is turned to 4x4...????
okay just to end this thread, I rotated the tires and did not help. I also replaced a hose clamp on the front drive shaft with a cable tie, replaced pass. side ball joints, pass side u-joint, and pass. side hub seal. After all that I took the truck for a six mile test drive and no vibration.(I did the same thing to the drivers side about two years ago). I am 90 percent sure one of those took car of the vibration. If not will update y'all
pete2294
06-25-2010 11:18 PM
viperbluelx
06-04-2007 06:30 PM
