Sponsored by: Real Truck
Front Driveline Vibration
Old Apr 30, 2009 | 06:21 PM
Newfietowncar's Avatar
Newfietowncar
Hey guys, got a problem. I have a 2001 F250 Super Duty Platinum Edition 4x4. I have recently replaced both front shocks and sway arm bushings in the front. Both sides have recent new ball joints. My problem now is a loud vibration when I hit some bumps on the road. I can drive for miles and nothins and the smallest bump and all hell breaks loose. The only thing that makes it go away at an instant is to put her in 4wd hi. I am thinking u-joints on the front diff or maybe the slip joint (slip joint was a problem a couple of years ago and was replaced with a new drive shaft, dad didn't know you could grease it until I read it here on FTE). Also if I come across another bump in the road after it starts is goes away. Anyhow wadda ya think. It's a diesel crew cab if that makes any diff. Let me know before i start pulling stuff apart. Thanks.
PS: Planning on goin through the brakes with new pads and rotors all around and the tires are just about gone but this noise comes and goes with different bumps in the road, not there all the time.
Old Apr 30, 2009 | 09:34 PM
EXv10's Avatar
EXv10
Strange. Possibly wheel hub bearings chattering from lack of lube, or something loose up front.
Old Apr 30, 2009 | 10:20 PM
DAVE67FD's Avatar
DAVE67FD
EXv10,
Don't want to sound too critical but is there a need to re quote his entire post? Its just curtious to save space here on FTE.
thanks
Dave
Old Apr 30, 2009 | 10:27 PM
EXv10's Avatar
EXv10
Originally Posted by DAVE67FD
EXv10,
thanks
Dave
Yea, I screwed that up but it looks like you are taking even more space.
Old Apr 30, 2009 | 10:28 PM
96sherm's Avatar
96sherm
how about your steering stabilizer??
where in newfie are you?? i'm a newf too, living/working in saskatchewan now...
welcome to FTE!!
Old Apr 30, 2009 | 10:31 PM
DAVE67FD's Avatar
DAVE67FD
And how is that?
Old Apr 30, 2009 | 10:44 PM
Newfietowncar
I put new hubs on in Dec (warn standard). I have a steering damper ordered.. Thanks for the reply. I live on the west coast (deer lake area) but am originally from the burin penn...
Old Apr 30, 2009 | 10:54 PM
EXv10's Avatar
EXv10
And how is that?
All that text that could be on one or 2 lines.
Old Apr 30, 2009 | 10:58 PM
EXv10's Avatar
EXv10
It sounds like something loose. Jack it up and shake everything and pry around with a bar. Shake your wheels too.
Old May 1, 2009 | 03:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like the classic dry needle bearing (inner spindle bearing) on the inside diameter of the wheel bearing, where the axle stub rides.
Old May 1, 2009 | 10:49 PM
DAVE67FD's Avatar
DAVE67FD
My intent on the comment to you was one to be curtious and two to clearly indicate that every post you respond to does not need a quote copy of the entire post. Most of us are not uneducated in the fact that we need a reminder of the post directly following it which is clearly visible within the same window.
I am sorry that my signature "size" was the only thing available for you to comment on as well as the fact that you finish your response with an admirable appology only to end with it being negitive.
I appoligize for any misunderstanding or offense you took to my response. I was only trying to give constructive critisism.
Old May 2, 2009 | 12:06 AM
EXv10's Avatar
EXv10
No problemo. It's hard to portray what one is precisely thinking with text. I will always accept constructive critisism.
Old May 2, 2009 | 08:59 AM
bohiaa's Avatar
bohiaa
MAN did you ever come to the WRONG PLACE....
these guys here know nothing about this issue.
you will get a few chime in saying you need a stableizer, then the ball joint guy will show up. then the wheel berring guy will jump in. and when you have just about had it.
some guy will say NOPE you need to have the drive shaft ballanced.
O yes and it needs a front end alinement. and ballance those tires. and your running too much or too little air in the tries..
I guess what's the funnyest one is. some guy will show up and say YOUR TAKING TOO MUCH SPACE .........
Save your self a ton of ageravation take it to a shop.
these guys here know how to change light bulbs, maybe a flat tire,
other than that. they will all just start crying.
and that reminds me.......... LET THE CRYING BEGAIN.......
Old May 2, 2009 | 12:00 PM
krewat's Avatar
krewat
EXv10,
thanks
Dave
Dave, you are doing us all a disservice. You have not posted ANY TECHNICAL information in this thread, just picked on the first person to respond. WASTING SPACE.
Now, leave this thread.
And you too can leave.
To the original poster, this sounds like the typical dry needle bearing inside the wheel bearing. The front axle stub rides in a needle bearing that sits inside the wheel bearing, and when you hit a bump, the bearing locks up and spins the front axle.
Two things to try:
1) Manually lock your hubs and see if the problem still exists.
2) Reach around back of the wheel, with the wheels straight, with the hubs unlocked, and try rotating the u-joint by hand. It should be somewhat hard to get moving, but once moving, be smooth and not gritty or ratchety.
Old May 2, 2009 | 04:00 PM
Monster-4's Avatar
Monster-4
I agree with Krewat sounds like needle bearing. If you do as Krewat said and it if does feel gritty then you want to pull of the wheel hub and lube them right way or replace them. If you don't you can damage the drive axle. Post back with what you find.
h20_guy33
Apr 11, 2013 12:42 AM
pete2294
Jun 25, 2010 11:18 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
JamesT96GT
May 26, 2008 09:40 PM
wolfmanagh
Aug 31, 2006 09:16 PM
