1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2014, 01:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Loose Steering in my F350.
Old 05-18-2011, 05:18 PM
jf2oo6's Avatar
jf2oo6
jf2oo6 is offline
I have a 99 F350 with the 7.3 diesel. The truck has 245k on it. The problem I have is there is play in the steering wheel. I have to turn the wheel about an eighth of a turn in either direction to get the wheels to respond. So in other words I can turn the steering wheel from about 10 o'clock to 2 o'clock without the front wheels responding.
Can you guys please point me in the right direction as to what I should start looking at first? I will go tug on any parts of the steering shaft I can reach and see if theres any play, but I'm wondering if theres any adjustments I can make. I appreciate any help.
Old 05-18-2011, 05:20 PM
jc8825's Avatar
jc8825
jc8825 is offline
You can try tightening the steering box. I haven't done it myself, but there is an hex key bolt on it. Don't make it too tight.
Old 05-18-2011, 07:24 PM
wizardsr's Avatar
wizardsr
wizardsr is offline
There's a lot of possibilities with that kind of mileage on the truck. Have someone rock the steering wheel back and forth while you watch for play in front end components under the truck.
Old 05-18-2011, 09:19 PM
jf2oo6's Avatar
jf2oo6
jf2oo6 is offline
Ok so I tried tightening the steering box one quarter turn, and that helped a little bit. I will try a little more tmrw. Kinda ran out of daylight today.
Old 05-19-2011, 11:39 PM
fbh31118's Avatar
fbh31118
fbh31118 is offline
Go to this link.
https://www.ford-trucks.com/forums/1...-problems.html
This will cover most of what your describing. This one really helped me after I bought mine. Keep us up to date on what you find.
Old 05-20-2011, 09:18 AM
rotun's Avatar
rotun
rotun is offline
Reads ***** rules!
Also check the BIG nut on the pit-man arm, really helps to get it on jack stands, wheels off the ground, KOEO and have someone rock the steering wheel in the dead space. Position yourself so you can see the shaft going into the steering gear and the pit-man arm in your peripheral, if the shaft movement does not match the pit-man arm movement then you'll need to start with tightening the worm gear mesh, follow the posted instruction and don't go too tight or you will bind the gears and not be able to steer! If that checks ok, look at the pit-man arm and make sure the movement between the arm and the shaft it is on matches, if not, you will need to get the right size socket and re-torque, I do it from the drivers side wheel well with the tire off. Next thing to check would be drag link, tie rod ends, etc. Basically you are having someone move the steering wheel in the dead space while tracing the input from the steering wheel all the way to the wheels. You'll find it this way.
Old 12-29-2013, 09:46 AM
DrtyJack75's Avatar
DrtyJack75
DrtyJack75 is offline
Thank You!! I just replaced my tie rod ends and connector link (or whatever its called) and there was a little play.....checked that pitman arm nut and BAM all better!!
Old 09-12-2018, 01:07 PM
Josh Ross's Avatar
Josh Ross
Josh Ross is offline
Diverdude
Love the info on this site! I'll be checking into my loose steering this week! It's been driving me nuts for months! Thanks guys!
Old 09-13-2018, 11:01 AM
brian42's Avatar
brian42
brian42 is offline
Holy thread resurrection! The internet really is forever!!
Lots of possibilities for the looseness. I would start with having someone turn the steering wheel back and forth and see where the slack is to start with. That might help narrow down where to start.
This isnt' rack-and-pinion steering so "tight" is a relative term. I've got about 1/2 the play you do and I'm thrilled. I may still have a small dead spot but I'm not herding the truck down the road any more since I put my new gearbox in. My tie rods and drag link are getting up there in age so I'm sure they add to the play/dead spot. Unfortunately the wallet doesn't support replacing them (again) for awhile.
Old 09-25-2018, 09:31 PM
Josh Ross's Avatar
Josh Ross
Diverdude
Good Kit?
hey all,
ive been pricing kits and was wondering what you thought of this one from Amazon. Much cheaper and free shipping. Does paying more get you more when it comes to steering?
6 PC Kit Steering Parts Ford Excursion F-250 SD F-350 SD 99-05 Tie Rod Ends Link https://www.amazon.com/dp/B071414P59/ref=cm_sw_r_cp_api_l7UQBbYZ25E9K
Old 09-26-2018, 08:28 AM
brian42's Avatar
brian42
brian42 is offline
In general you get what you pay for. If you are buying a kit that's about 1/2 of what a name brand cost (Moog, XRF, etc.) then you can probably expect it to not last as long. They do not look greasable so take that into consideration too.
While many do not pay the OEM replacement prices they do last awhile. I went OEM for replacements since I got 200K or so out of my originals. The replacements are still holding up at 316K.
Sometimes you can find a good deal out there get lucky. This may or may not be one of those times.
Old 09-26-2018, 12:39 PM
Josh Ross's Avatar
Josh Ross
Diverdude
Thanks Brian, yeah I'm thinking Moog. I priced everything Moog at Rockauto for $356 which includes the sleeve adjusters I may not need and includes shipping. Then I priced everything at Amazon (Moog) and it came to $350 shipped with the sleeve adjusters. Those prices also include a new stabilizer. Everything steering is original with 213K on them, so I would rather just upgrade all at once.
Old 09-26-2018, 04:00 PM
brian42's Avatar
brian42
brian42 is offline
I had Moog ball joints and did not have great luck with them. I do not have any experience with their steering components.
I have XRF ball joints and have been very happy with them. When my OEM tie rods are done this time I'm going with XRF's 99-04 steering kit (3rd one down): XRF Ford Truck Front End Kits | Front End Kits available from American Undercar
Their price (+ free shipping) is a little lower than Amazon (but no steering stabilizer).
Old 09-26-2018, 05:34 PM
Josh Ross's Avatar
Josh Ross
Diverdude
That looks like a solid kit. I’m gonna save that link for when the budget allows. Thanks!
BenGoers
2017+ Super Duty
06-01-2017 09:51 PM
Metal twister
12-04-2016 10:02 PM
Onebigtoy
11-30-2016 01:04 PM
deputydog03
Modular V8 (4.6L, 5.4L)
32
04-09-2016 12:06 AM
Eric3501
02-11-2016 10:15 AM
Quick Reply: Loose Steering in my F350.
