Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 07-12-2011, 06:46 PM
spidermantat spidermantat is offline
Garage is empty, add now
spidermantat is starting off with a positive reputation.
1990 f250 Starts than shuts itself off.
I have a f250 4x4 5.8 automatic. The truck will start run for 30 to 40 seconds then shuts itself off. Through research I thought it was the Idle air control valve So I installed a new one before that cleaned the throttle plates and surrounding areas. The truck started with the same result. The truck will keep starting if I shut it off before it shuts itself off. If it shuts itself off I have to turn the key off and wait. Then it will start and run for less than a minute. Any ideas and help greatly appreciated.
Last edited by spidermantat; 07-12-2011 at 07:42 PM. Reason: Didn't explain how long it ran.
Tags
1997, f150, f250, ford, shuts, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
