1990 f250 will start run for awhile then shuts itself off
I have a f250 4x4 5.8 automatic. The truck will start run for 30 to 40 seconds then shuts itself off. Through research I thought it was the Idle air control valve So I installed a new one before that cleaned the throttle plates and surrounding areas. The truck started with the same result. The truck will keep starting if I shut it off before it shuts itself off. If it shuts itself off I have to turn the key off and wait. Then it will start and run for less than a minute.
Last edited by spidermantat; 07-12-2011 at 07:41 PM. Reason: Sorry I didn't explain at first how long it ran.
Sounds like the same problem I had on my `90,found that the PIP sensor in the distributor was the problem.Theres some test that you can do to check it but you`ll need a degree to figure it out.Just try swapping the distributor with one that you know is good and see if it stays running.You can get the part for around $20 but you`ll need to press the dist. gear off to replace it.
Ethan1997
07-21-2016 09:44 AM
Leggeman01
10-30-2015 05:52 AM
