Hickery dickery dock, the mouse ran up the clock. The clock struck 12, the mouse ran down, hickery dickery dock.
Hickery dickery dock, I noticed your hubcap clock, didn't pay attention to what it was from. If I had known then, what I know now, hickery dickery dock.
Oh yeah, got the ole girl washed and waxed up, changed the oil in the air filter and greased up the front end, changed out the non working light bulbs and front lenses gaskets etc... one of the bed supports underneath is loose and half hanging out so i need to bolt that down. the add on wires under the dash has me puzzled, there is a rocker switch i cant figure out what it does. i have a new rubber mat on order. it will need a clutch soon, that about it.
It looks to me like it quotes the statute listed in the title on top. You might be able to find it online searching the state legal code or possibly the vehicle code.
There is a rocker switch, I can't figure out what it does.
Since backup lamps were not available until 1967, and your truck has them, maybe the switch is used to turn 'em on/off.
What are the backup lamps from? The answer is: 1964/65 Thunderbird, right/left is the same. This same lamp was used as the cargo lamp on 1967/72 F100/350's.
