2.3l no spark at two plugs
i have a 94 ranger with the 2.3l engine there is no spark at the ignition modual (the front one both on the drivers side) that controls the plugs on the drivers side of the engine. i swapped with the modual for the exhaust side but the problem stays at the same two plus and doesnt move with the modual what can be the source of this problem? ECU? thanks in advance
I thought the drivers side spark plugs were only active in certain circumstances. In other words, they don't fire all the time. I may be wrong, but have you tried putting a timing light on one of the plug wires and watching if it fires at all? It may be normal.
Do you have any codes or CEL/SES light lit on the dash?
tom
tom
Which two plug cyl numbers don't have spark????
I like tomw's idea to check for spark with a timing light.
If no joy, check the coil packs primary windings for continuity & it's electrical connector for B+ to each coil primary winding at KOEO.
If that checks out, suspect the coilpacks ground wiring for the troubled coil, all the way back to the computer, as it supplys the coilpacks primary ground switching, to operate the coil packs to fire the spark plugs, so if the ground wiring checks out ok, suspect the computers ground switching driver has a problem.
If all that checks out ok, check the end to end resistance of the two troubled plug wires.
They should measure about 1000 ohms/inch of length, 30k ohms max, no matter the length.
More thoughts for consideration, let us know what you find.
Right side of front coil not firing
Have a 1994 For ranger with the 2.3Liter engine. Front coil on right side not firing. Checked coil, Okay. Found problem to be ICM. Purchased a new from Napa. Model TP503. Corrected firing problem but now the truck will only run for 1 - 2 minutes before stalling. Returned the ICM back to Napa
and exchanged for more expensive unit. Model TP503SB. Same problem occurred. Returned unit back to Napa. After some conversations with the manager. Store refunded my money. Purchased used Motorcraft unit from wrecking yard. Truck runs great!!
Some of the aftermarket ICM's are not compatible.
teamsolu
06-21-2016 09:33 PM
jkait1982
2004 - 2008 F150
03-03-2014 05:18 PM
