1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Hood Spear Measurements
Old 07-03-2011, 01:57 PM
64blue's Avatar
64blue
64blue is offline
Can anyone give me the measurements for the hood spears? I am preparing the hood for paint and want to pre-drill the holes.
Old 07-04-2011, 10:25 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
I have some F250 hood spears if that would help I can measure them for you.
Old 07-04-2011, 11:35 AM
429unibody's Avatar
429unibody
429unibody is offline
I think he needs the measurement for the hole locations!
Old 07-04-2011, 03:08 PM
64blue's Avatar
64blue
64blue is offline
Yes, I need two measurements. I need the distance from the back edge of the hood to the first hole and the distance from the bottom for the first hole.
Old 07-05-2011, 11:16 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Ok here you go. If the 250 spears are the same. These will be your measurements.
From the back of the hood to the first hole I have 6 11/16 and it is 2 1/4 up from the lower lip on the hood.
The second hole in from the back of the hood is 14 1/8 and is 2 1/8 up from the bottom lip of the hood.
The last hole out is 21 5/16 from back of the hood and 2 up from the lower hood lip. All holes appear to be 1/4 in in diameter. Again these are for a F250 hood spear if the 100s are the same then you are good to go.
Old 07-05-2011, 05:09 PM
429unibody's Avatar
429unibody
Good job Buzz
Old 07-05-2011, 06:11 PM
Bill W's Avatar
Bill W
Bill W is offline
what year truck! the poster (64blue) does not specify. from the list in his sig which one is it?
Old 07-05-2011, 07:13 PM
64blue's Avatar
64blue
64blue is offline
Thanks Buzz, That's what I needed, i think. Bill asked about the year of the truck. Its a 61 unibody. However, I think the the measurements you gave me are correct.
Old 07-06-2011, 03:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The hood spears are the same 1961/62, and are all the same length regardless if for an F100 or F1100. These spears were not used after 1962.
Old 07-06-2011, 12:41 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Hood came off of a 61-62 F250 4x4.
OCS1934
23
07-08-2019 11:10 AM
willowbilly3
1947 and Older Ford Trucks
01-28-2016 06:40 PM
Gertie-The '49 F2
10-20-2015 12:09 PM
Fyrhosr
10-09-2015 06:18 PM
bobbyb1000
30
03-22-2012 01:03 AM
Quick Reply: Hood Spear Measurements
