4.6 Cams
What other supporting and compatible mods are you intending to do?
And you intended result?
Cams fall into two major areas, those than move the power band upward and those than provide more cylinder pressure at the low end.
There is more to this than you might believe at this time.
After mods like this a PCM custom tune is in order to get the most from the changes or just run it as it is..
The Comp Cams XE270AH won't do much for you below 3000, should have ported heads, intake throttle body work etc to get the most power out.
Good luck.
Good luck.
Well after talking to the people at Modular Head Shop, the torquer cams sound like a good way to go. They said it should increase it by about 20 hp and 40 lb ft. I'm not looking to make it a race truck or anything, would just be nice to have a little extra power when towing my GLH on my car dolly.
Sounds good. Do they give any performance specs?
I would like to see what the power curve looks like or where peak torque is made.
The numbers given are quite good.
I just visited their website.
Go down to the 4.6 PI section and look at the 46 Torquer.
The first line gives the stock cam specs.
Your looking at $600 for these.
Be sure you know how to follow their setup procedure.
I believe the cams are set up at 4 degrees advance plus have a little longer duration.
The cam advance builds cylinder pressure a bit higher by opening and closing the valves a little earlier in the cycle.
Good luck.
Good luck.
JV, Bluegrass is by far my superior in matters such as there but let me get some basic info from ya How many miles on the motor? another option for towing would be gears. If you have 3.55, go to a 3.73 or higher. As bluegrass mentioned, doing cams requires PCM tune and adjusting the tables for optimal performance. As far the PI intake, the answer would be no. ou'd have to change the heads to take advantage of the increased airflow, and that's more involved than you probably want to get into. Start with your little things first such as efans, then move on to the big stuff. How mechanically handy are you is going to be your limit.
The PI intake will bottleneck at the non-PI head ports, so it may even cost you some power since the port shapes are different.
Depending on the cam specs, I haven't looked, since the truck has a MAF, it will run pretty well without a tune on mild, smooth idle camshafts. Yes you can squeeze a bit more power with a tune. The Diablosport Predator I used on the 01 that I had worked well and they can write a custom tune when you give them all of your mods if you want to go that route.
I got better mileage running the 93 octane tune with 93 octane fuel than with the stock tune. Gained about 1.5mpg which made it actually cheaper to pay the $.20 more per gallon in the long run.
I agree, I would go tuner, e-fan, maybe exhaust (Magnaflow). A CAI will give minimal gains over the stock intake. Then look into cams. With 116K on the clock, I would definitely install new valve springs as well.
Oh, and since this is more engine specific, I have moved this to the 4.6L/5.4L forum.
never mind, i guess you never know this days:
http://forums.nmradigital.com/showthread.php?p=501471
although ive read alot of good stuff about him too..
