Nothing powers up in the cab.
I have an 08 6.4L F250. Bought it water salvage title etc. I replaced the batteries, keys, ignition. When I plug the batteries in the running lights, side mirrors, and inside lights turn on, but nothing else does with the key turned or not.
I have tried everything that I can think of besides starting to pull out and replace all of the wiring/pcm.
I have a few guesses at what may be wrong, but I would like all of your insight!
Yea, I pulled each fuse individually and checked. If I plug an Mustang SCT into the obd2 it also powers up, but cannot connect to the PCM, I am waiting for my actual SF3 for the 6.4L to see if it works.
Also pulled apart the fuse boxes, seem corroded underneath, is there a product out there that will eat the corrosion away?
Also whats the BCM?
Could an unprogramed key cause this?
Also whats the BCM?
I have heard that just a normal key would still power up the truck, just not allow it to run. I am wondering if this is the issue now...Nothing besides the outside lights and interior dome lights come on.
If the water damage was that bad I would be very cautious before you fire it up if you get that far. Our trucks are very sensitive to water in the fuel system. Maybe someone here can shed some light on what steps should be taken prior to turning over the engine with respect to the fuel system.
kscards
1999 to 2016 Super Duty
07-11-2015 09:02 PM
JRogersOU
10-25-2014 12:49 PM
