Rear fuel tank not working
My son just bought a 1990 F-150, 5 Speed, 4x4, 300 engine. We replaced the rear tank fuel pump, but the truck will still not run when the fuel selector is placed in the Rear Tank position.
Looking through the Haynes Maint. manual has not helped me much. I reaed thru the thread posted a couple years ago, but I'm afraid that wasn't much help either (or I'm too ignorant to understand it), so any help will be much appreciated!
Sounds like the fuel system might be OK.
But first you can either put on a new fuel filter or get a fuel pressure gauge and hook it to the fuel rail and see if it dies from lack fuel pressure (Approximately 30 PSI).
Normal running fuel pressure is 32-34 PSI at idle and about 40 PSI at WOT.
