'65 F100 tail light bezels
nope...bezels are 64-6 double wall bed type Styleside only. 67's through I believe 72 are squared off at the upper corners where it meets the tailgate to meet the trim on the gate...they also have a 3rd screw in the center as well...
Is this a driver or a restoration you are needing these for ???
I have a pair...one needs the buffing treatment...the other is dented...good to fill the spot if you dont have the moldings and wanna add it to jazz it up...
- cs65
- cs65
C4TZ-13489-E .. Right Taillamp Bezel // C4TZ-13489-F .. Left Taillamp Bezel.
Applications: 1964/66 F100/250 2WD Styleside / 1966 F100 4WD Styleside / 1966 Bronco.
1967/72 F100/350 Styleside, 1967/77 Bronco, 1969/74 Econolines use different bezels (C7TZ-13489-A Right & C7TZ-13489-B Left).
The taillight lenses are also different. 1964/66's do not have backup lamps. The lenses used w/the C7TZ bezels have the backup lens incorporated within.
If adding backup lamps to these specific 1964/66 vehicles, the 1967 style lamps/bezels bolt right on like they were made for them.
Blaster900
03-08-2017 09:11 AM
78 PEB
12-25-2015 02:27 PM
