'59 bezel clips
Old Feb 27, 2016 | 11:53 PM
SeaCarr's Avatar
SeaCarr
'59 bezel clips
Wondering if the 1" clips located on the grill to hold the upper edge of light bezels can be bought? Or someone have a non repairable grill with the clips. I need one clip.
Old Mar 5, 2016 | 10:15 AM
SeaCarr's Avatar
SeaCarr
Surprisingly, I measured a good clip to get the exact size, found a metal strip and manufactured a replacement clip that looks as good as the original. So, moving on with the 1959 grille.
Old Mar 5, 2016 | 10:28 AM
theodore/teddy's Avatar
theodore/teddy
Refyred
Could you post up your fix for this? I have one missing clip on a spare grill I would like to repair! I have not run across any thin spring type metal that seamed like a good replacement. Although I have not put any serious effort into it.
Old Mar 6, 2016 | 12:42 PM
SeaCarr's Avatar
SeaCarr
Smile
Searching the Internet for "spring steel" I found there was no consensus that "spring steel" exists in a form one can purchase in small amounts. i visited all of the local hardware stores and found nothing that would appear to work. Time was dragging on so i visited my unorganized metal scrap pile and found a six inch piece of steel that was hard but flexible if that makes since.
The original clip measured .037 or 1/32" thick, width was 1", length was 1 and 1/16", plus or minus 1/16".
I laid the original piece on the new and marked two holes that were drilled with a 9/64 bit. I then measured up from the bottom and cut the top.
The two outside clips are different from the two inside clips. The bends are at an angel with the wide edge to the outside if you are replacing the outside clips.
The most difficult part was getting the folds correct at the top but with a little experimenting with small vices I got the folds much as the original looks.
i then used two rivets to hold the clip to the grille. Placed the bezel on and with the one screw in place it seems to be a good fit. The washers in the photos are just to hold the clips open. They are pretty tight with out them.
Old Mar 6, 2016 | 12:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO pictures, grille above, headlamps below. Which clip are you asking for?
Old Mar 6, 2016 | 01:21 PM
SeaCarr's Avatar
SeaCarr
I made one that appears to work. Thanks for your reply.
Old Mar 6, 2016 | 06:31 PM
theodore/teddy
Refyred
Bill; the clips that Seacar made are not shown.
Thanks Seacar, I appreciate the info! I will give this a try!
harleyjoeky
Oct 5, 2020 02:57 PM
2quickM100
May 31, 2012 06:35 PM
vanwashe
Aug 16, 2011 02:50 AM
78bigbronco
1997 - 2003 F150
Apr 25, 2006 10:40 PM
marvinlong
Feb 4, 2005 08:30 PM
