AC leak ?????
Old 08-30-2011, 05:46 PM
meier63's Avatar
meier63
meier63 is offline
AC leak ?????
Hello all, I have an a.c leak. It usually takes about 2-3 weeks for all the refrigerant to leak out and start blowing warm air. I have used stop leak with no luck. I want to use some dye and a uv light, but dont have the extra money for the light right now. My question is , after charging the system, and getting ice cold air..... I shut the engine off, and I hear a hissing sound which lasts for about 30 - 45 seconds. It seems like its coming from the dryer area, but when I spray soapy water around all the fittings ,I get no bubbles? The sound is like air escaping...... Is that a normal sound to hear after shutting down, or could this be the source or the leak somehow? Thanks for your help Bill
Old 08-30-2011, 09:21 PM
stuart1's Avatar
stuart1
stuart1 is offline
You will have a terrible time getting anyone to repair the system after you put sealant in it.
A hissing noise is common.
For a proper repair the system must be evacuated and repair whatever is leaking.
Not one person will jeopardize their recovery machines when they discover sealant.
Old 08-31-2011, 07:22 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
If it's the 99 in your sig, it has dye in the system from the factory.
You can use a cheap UV light from Auto Zone, but you need it in the garage out of full daylight. It also helps to shade the engine compartment. The available yellow glasses help a lot with the UV light.
Pay close attention to the compressor body and even remove the clutch plate to check the shaft seal.
Look for signs of oil/dirt around all of the fittings and crimped hose connections. Dirt/oil usually means a leak.
Regardless of where the leak is, you should flush the sealer out of the system and replace the accumulator and orifice tube.
Old 09-03-2011, 02:14 PM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
The hissing sound when you shut down is just the freon equalizing pressures in the system.
meier63
08-30-2011 11:05 PM
lostmybeer
07-05-2011 09:57 AM
jkarne
2004 - 2008 F150
03-16-2011 09:10 PM
99Exp
1997-2006 Expedition & Navigator
07-03-2009 05:59 AM
ronnidonni
1983 - 2012 Ranger & B-Series
05-27-2006 06:40 AM
Quick Reply: AC leak ?????
